Log Premium ITX Case that can hold Dual 240mm AIO Radiators
Duppex
Can anyone advise me of a Premium ITX Case that can hold (Dual 240mm AIO Radiators)
I am planning a new build using a RTX 3xxx Hybrid card which has been confirmed will have a 240mm AIO.
I also want to use a NZXT X53 240mn CPU AIO.
The case that I really want is the Streacon DA2, I also would consider the NCase M1 V6.1 but I don't think any of them can hold Dual 240mm AIO.
Any Premium ITX Case recommendations that will work would be much appreciated.
zk2004mb
58
32
For Ncase M1, I can confirm that you won't be able to use it unless you put your bottom fans outside the case and switch longer foot.
You can consider the NR200. I'm not 100% sure that you have enough space at the bottom because it really depends on the design and thickness of GPU waterblock but it should be your best bet.
Duppex
Thanks for the info. I am going to research the NR200 ?
I want a case without glasse side panel but if I cannot get an 3080 Hybrid + Kraken X63 to work in one of these cases I may go with the
Lian li 011D Mini when released this October. I know it's not SFF but does look Good
ermac318
655
510
Cerberus X, Dice Flow, CoolerMaster NR200 (maybe), Fractal Design Define Nano S, and then you get into 30L+ cases like the LL O11 Mini, FD Node 804, Corsair Crystal 280X, Phanteks Enthoo ITX etc.
EDIT: Ghost S1 with double Large Top Hat would work too
tinyitx
2,279
2,338
Cooler Master NR200 could do 2x240.
Here is one with 240+280 (he modded the rear to add an iceman res/pump for his custom loop).
Another 240+280 custom loop here:-
2x240 usually uses the bottom and side panel for rad. If you do excellent planning, even 3x240 is possible with the 3rd 240 at the top.
However, NR200 is not considered 'premium', price wise. It is a sub 100 USD case. Premium cases often start at 200 USD. But this is not an issue as NR200 is so full of features!
Duppex
@tinyitx
Thanks for all the info ?
Think I will grab an NR200 and combine it with an 10900k + Kraken X63 + RTX 3080 on Air. Then wait for the 3080ti/super Hybrid version and see if it fits.
Or just sell the 3080 Air card and NR2000 Case, then upgrade to an NCaseM1/Streacon DA2 Case with a RTX 3080ti/super full custom water loop ?
