Hi! I'm currently building a theatre lighting control console. It'll contain an Intel NUC computer, plus some stuff to control it (a custom keyboard, a few motorized sliders, some SK6812 LEDs to backlight the keys, a couple of OLED displays, and all driven by a pair of Teensy boards).
I'm currently looking into how to power everything. I want the entire power supply (including AC->DC) inside the unit.
The NUC has its own DC->DC regulator, and can take an input of 12-24V DC. For the rest of my components, I definitely need both 5V and 3.3V lines, possibly also 12V.
I guess I'd get an AC->DC supply that outputs something the NUC can accept. Then connect the output from that to both the NUC's input, and also to a DC->DC board to power the rest of my components. Does that sound reasonable?
Current draw will be low compared to the builds I'm reading about here! The NUC normally comes with a 65W 19V power brick. And while 120 LEDs will draw a non-negligeable amount of power, that still won't put things in the ball park of you guys who are running huge graphics cards!
I was looking at a Meanwell AC/DC supply paired with a Pico X. I'd probably get the lowest wattage. Does this sound reasonable?
Given that the NUC can take input between 12-24V, is there an advantage to picking any specific value for the output of my AC/DC PSU?
