I'd prefer to avoid the molex external power brick because though it works, it is meant for fans and lighting and some reviews mention it killing drives (though others have had success with drives). Could I split one of these (from the manual):
• External Power Supply – the board can be powered through a 12-24 V DC connector on the
back panel. The back-panel DC connector is compatible with a 5.5 mm/OD (outer diameter)
and 2.5 mm/ID (inner diameter) plug, where the inner contact is +12-24 V DC and the shell is
GND. The maximum current rating is 10 A.
• Internal Power Supply – the board can alternatively be powered via the internal 12-24 V DC
2 x 2 power connector, where pins 1 and 2 are +12-24 V DC and pins 3 and 4 are GND. The
maximum current rating is 10 A (5A per pins 1 and 2).
The connector used is Molex Micro-Fit (3mm pitch), right-angled, 4-pos/dual row (2x2).
I'll use the combined SATA connector for my system and apps, the 2280 for DVR recordings, and the 2242 with two DC HC530s for my Plex collection. The 2242 slot is gen4 x1 and I plan to adapt it with
this.
