hrh_ginsterbusch
713
279
wp-devil.com
This is just a placeholder for now, but as soon as I've disassembled everything in the S400 v2 and start moving it into the K77 Lite, this is gonna be updated.
Case: K77 Lite (11.6L)
Specs: The same as of my portable workstation (Ryzen 9 7950X + RTX 4070), but going to try out different air cooling solutions (Silver Soul 110, Noctua NH-D9L, Silver Soul 135).
Modding plans: Replace side panel with mesh, maybe try out side-mounted 140 or 240 AIO.
cu, w0lf.
hrh_ginsterbusch
713
279
wp-devil.com
Have finished disassembling the S400 V2 build.
Findings: Sadly, the HDPlex GaN 500 is too tall for this particular combination; would work if my GPU was shorter.
So its back to the SF750.
Other findings, about the case itself: A 120 mm slim fits on top. But even a 140 mm slim (Air Slimmer) fits!
Also, at the bottom, a 140 mm Silent Wings 4 Pro fits as well (two would fit). Oh, and of corpse regular 120 mm fans (tested with Arctic P12 Max). Obviously it'd be all zip-tie action, but nevertheless, not a bad amount of options :)
Decided to unplug the USB + on/off switch, nearly losing the actual button. Gonna replace it with a cut-to-size option of the S400 V2 switch, hence glowy lights :D
cu, w0lf.
