ALright Thanks!!! So, Thestarkiller32, This one (
https://m.aliexpress.com/item/32829...Slot-Transfer-Card-Mining-m-2-Riser-with-sata) Requires me to plug in BOTH a molex AND the 6-pin, or just one? I think that is the route I will take, Mainly because of the nice mounting holes in the PCB and no ribbon cables to deal with. But if it requires both the molex and the 6-pin, I may have to make my own cover and plug to have it look nice. There also seems to be another sataplug at the far end marked "power" and in the picture, they only have that plugged in. So does it just use one of the plugs?
Thanks, Windfall
Edit: I found it in the description. Only one is required. I also found another one with JUST the molex and USB, and it's a lot more clean. I'll probably go with it.
Edit #2: So, according to kmpt, I'll lose 20-30% of performance. Any way to bypass that, besides going with a normal adapter?
