CPU PCIe x16 3.0 riser cable for GPU that's a ribbon not a blanket?
Lux
If I understand correctly, you are looking for more of a standard cable solution rather than a ribbon.
Its pricy but I think the best solution would be the GPU risers made by Comino. It uses a newer connection called OCuLink, which is becoming common with server hardware.
https://comino.com/en/risers/
Good luck with your project.
robbee
n3rdware
855
1,335
The Comino riser has a MOQ of 100 :(
Lux
I searched and couldn't find anything on their site or elsewhere that states that. Did you request a quote from them to find that out. I believe you, I'm just curious.
robbee
n3rdware
855
1,335
Yeah, I asked for a quote a while ago... It's a shame because many cases could benefit from this riser!
W4RR10R
211
211
I am looking for Something like this PCI-E x16 3.0 Black Extender Riser Cable 300mm but with the ribbons stacked instead of in parallel
Any Suggestions?
Would it be a huge performance hit to use a PCIe 3.0 x4 to x16 cable ?
Planning to put a passive GPU ( GeForce® GTX 1650 KalmX ) in empty upper space my Sff and don't want to cover up everything...
Where are you getting the 1650 KalmX, Ive been looking for one for a project, I dont even need the cooler, I need it for its ludacrisly small pcb.
Kommando
78
54
I wonder why no one sells those Comino-Risers.
I need them for my Sliger CL530. Would really help with thermals. The ribbon style riser blocks nearly a whole fan.
Gilles3000
240
243
Price I'm assuming. Only price i've seen quoted is €99 and I'm not sure at what MOQ that is. And tbf, that's quite cheap, just 2 of those x8 Oculink cables alone tend to cost around €100 already.
Kommando
78
54
That's a steep price indeed. But it wouldn't differ much from the price of the normal cables.
PS: MOQ is minimum order quantity. :/
