Hi all,
I ordered some tiny cases from China, got bored of waiting and built this case, it’s quite large for me at 17L
Spec 7700k, 16gb ram, 1060 EVGA sc mini, 120gb m.2 for operating system and further SSD’s to be added, 500w sfx-l silverstone psu.
Case has a 120mmx25mm fan at the top, and 80x25mm at the bottom, a separate opening for the 120mm PSU fan to take air in.
Cpu cooler is a Thermalright AXP-100r which I initially started testing with a 92x25 Noctua fan, then created an adapter for a 120mm fan, and have now created a 140mm fan adapter which I am still yet to test.
There will be a Perspex sheet arriving imminently for me to have a window on the front. The ‘door’ is hinged.
The IO ports just have 90 degree cables plugged in which go to the rear of the case to connect up.
Let me know what you think
