NZXT Kraken X52 fitment into M1 V6.1
Zelfiris
Hi Everyone,
I'm a new owner of Ncase M1 and loving it so far. I'm looking for some help/feedback regarding fitting in the Kraken X52 AIO.
I side mounted it with the radiator in front and fans on the inside (as per Optimum Tech's suggestion). However, I cannot direct the hose down as they were fitting the fans. In the photo, I directed the hose up, allowing the fans to spin. But my case top panel is constantly getting pushed up.
Any suggestions, aside from switching to a new part?
2,668
2,792
Hi Everyone,
You have fan grills included with the case, just use those.
