When Nvidia released the Original GTX 1650 cards in mid 2019 with 4GB of DDR5, they met with very poor reviews. Despite having around 35% more performance than the GTX 1050Ti it replaced, more was expected of this Turing model.
The release of the GTX 1650 Super later in 2019 made the “vanilla” 1650 even less desirable for most as it offered 35% more performance for only $10 more.
For most people buying a graphics card the size and power consumption of a graphics card aren’t something they worry about, however, if you’re looking for a small GPU which doesn‘t require external power the GTX 1650 may be one of the better options, especially as they’re also available as half height cards.
So, without much fanfare, and probably without many reviews, Nvidia has upgraded the GTX 1650 from DDR5 to DDR6 memory. This will get you from 5-8% more performance at the same power consumption (core clocks may be lowered to keep it at 75W).
If you’re in the market for a GeForce GTX 1650 I’d suggest looking out for one of the new DDR6 models.
