Hello everybody!
I am running my fairly simpe build for quite some time now and I am happy with the raw power.
Photo of my build
I knew I had to do some undervolting to get atleast decent temperatures. Now I am thinking about what I can optimize to get better temperatures.
The C14S is doing a good job on my 5800x and I never get temperatures above 80 degree even under heavy load but I think this cpu cooler is a bit counterproductive for this combination because the hot air from the gpu is heating up the case. A slim fan above the cpu cooler did not improve the temperatures. A second 25mm intake fan at the rad panel also did not change anything.
My idea is to change the C14S for an AIO like a Kraken X63 to get more space above the gpu. The rad could be mounted as intake on the rad panel. Additionally I can add another 25mm top case fan as exhaust to transport the hot air faster out of the case. I tried to find some setups so I can do some research before I start changing components but sadly I could not find any.
What do you think? Could this lower temperatures enough to be a reasonable step to take? Or maybe another air cooler would fit this situation better?
I appreciate any feedback! Thanks in advance.
Best regards,
SteveTheThief
Photo of my build
Best regards,
SteveTheThief
