Hey there!
So i actually started a PC build, hadn't planned to do a build before Cerberus was out however it seemed like that could take some time.
The case I decided on was the Node 202 from Fractal Design with the bundled PSU because although quite large and the PSU rather loud it was good enough for the time being and I had always wondered if the space inside would allow for a liquid cooled setup. I'll get back to that later on.
As for the components, I got some basic parts that should be quite enough for me going from a basic laptop.
I got the CPU and MB bundled together, pretty much bringing down the CPU cost to i5 6400 levels.
Processor: Intel i5 6600k
Motherboard: Asus Z170i Pro Gaming
RAM: 1x 16GB Corsair ValueSelect
Graphics Card: Gainward GTX 970
Storage: Intel 540 480GB M.2 SSD
CPU Cooler: Schyte Big Shuriken 2
Case Fans: 2x Noctua NF-F12
I was not able to get any photos of building it due to poor lighting and space but here are some I actually could take!
As you probably see the cables are somewhat tidy but honestly I feel it's horrible compared to some motorcycle wiring I've done... Anyway, let's continue...
Using the PCI-E power cables to help keep the GPU not sagging.. Have some rubber spacers now though!
The rear also got camera attention.
Overall I'm quite happy with the current config, the CPU cooler with some CPU undervolts and 4,0Ghz clock is barely audible on gaming or movie/video loads.
The GPU and PSU are very load though, but managed some GPU overclocking with lower voltages.
The case fans help keep a steady airflow through the system in both vertical and horizontal positions.
The SSD does get a bit toasty under heavy load but haven't had it throttle yet, the capacity is good enough until I'll start playing more modern games.
Now onto some future plans!
I will most likely liquid cool this PC!
I have the dimensions confirmed for a DDC pump, 240x23mm rad w/ 2x 120x25mm fans, blocks and fitting for a single slot I/O GPU and the CPU.
A res is so far not on the list.. however.. depending on some external factors.. a CPU block/res combo might just happen but it's not very likely!
The Corsair SF600 PSU is also on the to get list.
I did get the 970 used, just because it would hold its value better when later selling it in favor of some newer more powerful single slot GPU.
Hopefully we'll soon see a single slot 1080 or something with similar performance from Radeon so I can start the liquid cooling.
I also plan on either a paint job or just getting some vinyl wrap to take the exterior to higher level.
Will also try and get concept art, updated photos and the likes on here as time goes on. Thanks for droppin' by!
I hope I've followed the forum rules, I also hope the images are working.. (First time creating a forum post/thread.. ever.. in my life)
