Hey guys, SFF novice here.
I was thinking about building myself a PC and prepared a list of all the components. Could you help me out and point out any obvious mistakes?
My main concern right now is the clearance in the GPU compartment. I can't find the exact GPU width (other than "dual slot"), so the two NH-P12 might not fit?
Perhaps somebody could point out whether or not this will work. Otherwise I'm just going to try. Worst case I'll return the fans
Other thoughts:
- chose 1x 16GB RAM because I will most likely "upgrade" with a 2nd 16GB stick in the future
- as this is my first ever PC build, I decided to use only M.2 storage; this will probably make life easier during assembly.
- 450W PSU too low? I don't really think I will ever go higher in TDP with my future GPU or CPU upgrades
Many thanks in advance!
System Builder
pcpartpicker.com
Other thoughts:
