CPU No GPU, use a Dan A4 H20 or....
skippy
Hi everyone, have become engrossed with the idea of building a SFF as a work desktop for myself after I realised the full size power people were getting in to sff. Have reads heaps here so far and learning a lot, thanks.
I am just doing the research for a build utilising a i7 12700, 32gb and B660 chipset, with no GPU as not required for work. I was wanting to go with an AIO for quietness and performance. I was thinking of using the Dan A4 H20 as I really like the design and understated function of it. Also like the high quality finish of some alloy cases. I wouldn't be utilising the GPU compartment and while I could stick a fan in there blowing at the back of the motherboard I can't escape the feeling I am not utilising the case to it's best or utilising the best solution to my problem. Does anyone know of a similar size (or smaller ) case which would suit better, should I modify a aliexpress one or just stick with the Dan one? Any suggestions or ideas welcome.
makoto14
my 2 cents is Dan would be really OP for you. If you are willing to enforce the 65w power from your chip you can use a inwin chopin or a desk mini and power your setup for less cost and a smaller desk footprint
skippy
Thanks Makoto, to be honest I hadn't thought of it the other way, by limiting chip power. Thank you, gives me some other options
hrh_ginsterbusch
139
54
wp-devil.com
When you go down the DeskMini road, you could also look into other < 10 L cases, eg. the DeskMeet B660, the Ophion 7L or the Densium 4 / 4 Plus.
There is a great video about the Raijintek Ophion 7L by F7GOS, that indeed makes one drool to get that case:
cu, w0lf.
makoto14
yeah, the default BIOS settings for most motherboards let the chip boost forever at max power so you end up with a 12700 that is using 200w on a all core work load. but if you actually see the recommended intel specs for a 12700, the chip runs at 65w normally and boost to like 180w for less than 30 seconds. Cooling a 200w chip in a sub 10L case is going to be tough, cooling a chip that only 180w for 30 seconds and the rest of the time is at 65w is pretty easy even in a sub 10L case.
Reactions: skippy and rfarmer
