Night Shade (200W, SFF Build)
dKenGuru
295
199
Saint-Petersburg, Russia
dken.guru
Parts:
CPU:
AMD Ryzen 5 3500X
Cooling:
  • EK-Velocity - AMD Nickel + Plexi
  • Innovation Cooling Graphite Thermal Pad
  • Alphacool NexXxoS ST30 Full Copper 120mm radiator V.2
  • Swiftech MCP35X DDC Pump + Bitspower DDC Top/Case
  • EK-CryoFuel Solid Cloud White
  • DarkSide Gentle Typhoon Performance Radiator Fan (550-1850rpm) 58cfm - Black Edition PWM x2
  • EKWB Turque Fittings
Motherboard: ASRock AB350 Gaming-ITX/ac Mini ITX
RAM: G.Skill Flare X Series 16GB (2 x 8GB) DDR4-3200 F4-3200C14D-16GFX
GPU: PowerColor AMD Radeon RX 5500XT, 4GB
Storage:
  • Samsung 970 Evo Plus 250Gb NVME M.2
  • Samsung 860 EVO 1TB 2.5"
Sound: Khadas Tone Board + JDS Labs Atom Amp
PSU: HDPLEX 200W DC-ATX
Case: Sliger SM560 with add-ons
OS: Windows 10 Home, 64-bit
Overclock:
CPU:
4.3Ghz, vCore 1.35v
Memory: 3733CL16, T1, Geardown off, 1.45v (no 0.01 step in BIOS)
Temps: CPU: 35°C idle, ~70°C on full load, DIMM: 35-45°C max
Was on 3400G
CPU: 4.1Ghz, vCore 1.36 (no LLC on MB, drop to 1.28 on load)
iGPU: 1700, vGFX 1.1625
Memory: 3466 Mhz CL14/3533CL16, T1, Geardown off, 1.45v (no 0.01 step in BIOS)
Temps: CPU: 30°C idle, ~65°C on full load, DIMM: 30-45°C max
Plans for upgrade:
GPU to AMD RX5600XT if ITX variant will be. Undervolt
MB to something to B550 after release
Must be ~200 Watt. If not PSU to HDPlex 400W
dKenGuru
295
199
dken.guru
I got Ryzen 3500X and RX 5500 XT 4Gb from PowerColor in ITX format. Will try overclock it and power from 200W.
3500X already working fine with 4.1Ghz @1.35v and 3733Mhz, CL16, GDM Off, memory (IF can't work at 1900). Tested on my X570 Gigabyte.
My good sample of 3400G will be sold.
Reactions: owliwar
