Hey guys,
I'm currently in the process of laying out hardware for my case design.
I've come to a point where I'm not sure which radiator to pick as this also affects the overall footprint of this m-ITX case design.
The loop itself is supposed to have a 1080 ti FE with EK waterblock and i7-8700k with an EK motherboard monoblock.
I'm not really going for 24/7 OC on these and I plan on undervolting CPU, delidding etc. to have low temps.
I can either pick an EK SE 240 rad which is 280 x 120 x 28mm (L x W x H)
OR an EK SE 280 rad which is 320 x 140 x 28mm (L x W x H)
So the footprint will be 280x120 or 320x140.
Of course I prefer the smaller footprint, but bigger rad will keep the loop cooler and 140 fans will get some more air going inside the case itself.
I've never did a small build, do you think 320x140 is big for m-ITX case? Are these ' 40x20mm ' extra worth the lower temps?
Or is the 280x120 mm neatly small and 240 rad will do just fine?
Considering I'm not really going to OC it I think 240 will be just fine but I'm not so sure..
So what you think guys?
Cheers
Cheers
