Hey guys,
I purchased an HDPLEX and was looking to connect a single sata connector to the 4pin connector on the PSU. As you can see the pin layout is as follows:
Now, I don't know if this is normal, as I thought it was the two 12v on top, followed by two grounds on the bottom?
Anyway...I ordered a 4pin atx to sata adapter that looks like this:
As you can see, it seems like the top two 12v wires are going to a single terminal? Is this normal and will it break my system? You can see in the bg listing the photo is different than what was sent.
I guess, on a final note/question...what is the correct wiring for a 4pin ATX to sata with the HDPLEX 250?I was under the assumption it was wired
V V
======> VGGV
G G
But on the HDPLEX it seems like the PSU is wired:
V G
G V
V V
======> VGGV
G G
V G
G V
