I have the following requirements for a PC:
- Fanless
- Small enough to be mounted behind on VESA brackets if need be
- Need to have minimum 32GB of RAM
- Powerful enough to handle heavy office applications and web browsing
- Onboard GPU strong enough to handle G9 Odyssey 49 inch screen
- Price is not a factor when deciding the hardware
I have been trying to look for a fanless design but not seeing many alternatives. I see Akasa has some cases but then I am struggling to find the motherboard that will work inside it.
Thanks for all the help in advance.
- Fanless
