Hello everyone. I've just completed my NCase M1 build with the following spec:
Core System:
Storage:
Cooling:
Sound:
However now I have had some time to play with it extensively the initially fantastic performance of the Kraken AIO G12 I falling a little short. I was playing PUBG TDM last night at 3440x1440 98FPS locked and temps eventually reached 73C (after around 3 hours) and crashed (Higher temps usual results in higher voltage required to sustain a speed and my under volt didn't like the higher temps). Perhaps I need to have another go at reseating and pasting it? It seems after extended plays the cooling solutions becomes overwhelmed?
Has anyone had any luck getting an H80i v2 in there (I'm also looking at an older H70)? Or can anyone offer any suggestions to improve my GPU temps? Obviously I won't be able to run push pull but I figured a deeper radiator and ether a 15 or 25mm 120mm Noctua in pull config would be better than a 25mm radiator with x2 25x120mm Noctua's in push/pull.
In addition I only have x1 15x120mm noctua fan at the bottom of the case blowing air over the VRM closest to the IO shield and the the 92mm Noctua mounted to the G12 bracket blowing air back across the card.
Anyway here are some pictures. Any feedback most welcome!
Core System:
- Msi Gaming Carbon z370i
- 9700k @ 5.1ghz 24/7
- Gigabyte Gaming OC 2080 ti
- Corsair SF750
- 16Gb Corsair Ddr4 @ 3700mhz
Storage:
- Saberent 1tb M.2
- 500gb Crucial SSD
- 2tb Samsung HDD
Cooling:
- Kraken G12 + corsair h50 - GPU (Noctua redux fans on rad and bracket).
- Corsair H60 CPU
- Noctua Redux 1700RPM fans
Sound:
- Creative G6
- Sennheiser 6XX cans
