Hi guys,
So I purchased an M1 and I have been looking a bit into parts and such. My aim is a fast computer with minimal noise, which i expect will be hard with and almost open-air case like the M1. I am looking for any inputs and guidance, and I have a few questions as well. My ideas of the setup:
CPU: i8700 (non-K), 65W - delidded
CPU cooler: Noctua NH-U9S tower (removed: Noctua NH-L9x65 (blow-down cooler))
Motherboard: ASUS ROG STRIX Z370-I GAMING (5x PWM fan connectors)
RAM: g-skill 3200 MhZ CAS 14 (F4-3200C14D-16GTZ)
PSU: Corsair SF600, possible fan mod with 92mm Noctua slim (removed Be Quiet 500 MhZ SFX-L OR Corsair SF450)
GFX: GTX 1070 mini
Hdds: 1 or 2 3.5" disks - installed in cage on bottom towards the back, 2.5" SSD, Samsung 960 pro 512gb M2 NVMe card incl Far Cry 5 (samsung promotion)
Fans: - outtake, on the back: Noctua NF-B9 Redux-1600 PWM 92mm (25mm thick)
- intake, side (front): Noctua NF-B12 Redux-1600 PWM 120mm (25mm thick)
- intake, bottom (front): Noctua NF-B12 Redux-1600 PWM 120mm (25mm thick)
So I have several questions on mind:
a) Will the CPU cooler suffice and is blow-down a good idea? I could also go with the tower Noctua, but I like the idea of blown-down cooler as they are easier to clean in between the years.
b) I would really, really like a PSU with a semi-fan less mode, but it seems that I need to go SFX sized power supply. Does anyone have experience with the 92mm corsair SFX vs the 120mm Be Quiet ?
c) HDDs - will it fit 2x 3.5" with fairly ease?
d) Fans: I am very uncertain on my fan setup. Is it really not possible to get air in from the front? Also, is there any issues with the fans being 2.5 cm thick?
e) De-lidding. Is this really necessary? I mean, they say it will give you 15-20 degrees less on CPU and in my mind that translate directly to less noise. It is a bit pricey at around 100 €/$ but it sure is tempting for that kind of temperature reduction.
Anyways, if anyone can help it would be nice :-)
GFX: GTX 1070 mini
