Naming-How do I get "noticed"?
6,075
5,007
If you put a volume number in your topic, to me it means the emphasis is on the volume more than anything. Not every SFF case needs to be the smallest as there are many considerations to reach a smaller volume. Otherwise we'd all be using 4L mITX cases.
Reactions: Biowarejak and el01
Duality92
307
330
It's all about the presentation. The hook is the most important part.
Go look at Overclock.net sponsored build log section and check some of them, you'll see presentation is key. We aren't sponsored for nothing.
Choidebu
"Banned"
Aug 16, 2017
1,199
1,205
For naming, go skandinavian/nordic/viking ish, can't go wrong with it - people dig em, they lo-ove ikea.
I got one for you.
Eyjafjallajökull
Just rolls out of your mouth isn't it? Go ahead and use it, it's common CC.
el01
770
588
I got one for you.
Eyjafjallajökull
What about:
vaðlaheiðarvegavinnuverkfærageymsluskúraútidyralyk
:D
el01
770
588
According to google translate, that is "The front door of the workshop makes it look like the outside". Uwhut m8?
I just searched up the longest Icelandic word.
Even better:
Take that, do unicode numberings, then translate those to binary.
"Introducing the new 101011110101010101110101010101001010101001010101011011010010101!" (this actually doesn't mean anything)
