EDIT:
The project is finished, you can find the outcome here:
/EDIT
Hello all,
I recently got into the SFF world, especially liking the Velka 5 and other small footprint cases.
No case ticked all my boxes though, so I thought it would be a fun project to create my own case.
This is the result so far...
Style: tower sandwich case for full size GPUs
MB & GPU IO to the bottom, partly rerouted to the back
Construction method: 2mm lasercut stainless steel, assembled with threaded cubes M3x12
3x 92mm case fans at the front (or 2x 92mm fans & 1x 92mm AIO) - additional option to mount 2x 92mm fans externaly to the back
Handle at the back for easy carry
The design for the outer panels is not fixed yet.
My current plan is a solid wood top and (1mm ?) coated steel side & front panels
Here is a pic how that could look:
Dimensions of the skeleton, ignoring protrusions: LxWxH 195x120x352 ( 8.24 l)
Probable final dimensions, ignoring protrusions: LxWxH 200x122x367 ( 8.95 l)
Current status:
skeleton with working hardware build
Views from all sides:
In theory, there is enough space in the upper front to fit a 92mm AIO
If I actually wanted to fit one I would really need a custom cable for the 24 pole connector.
Instead, I will probably put a third fan in there to work as an exhaust.
The lower two front fans work as air intake.
IO compartment - not a pretty sight but normally hidden from view when the side panels are finished.
I plan to add a cutout in the back for the ethernet adapter.
Some build pictures:
Lasercut - I went with a single part because the shop of my choice charges an extra fee per part
First assembly after some tapping, counter sinking and cleanup
Hardware: not really important as my focus is more on the case, but here it is:
Next steps:
- Deciding on how to fit the Panels to the case. I see two options:
1) screw them on
2) fit Magnets to the frame and snap mild steel panels to them
- fix the design of the panels
- find a supplyer for the panels (cutting folding, finish)
- create the wood top as soon as the panels are ready (I can do that myself)
Let me know what you think of my efforts so far.
Do you have suggestions regarding the next steps?
My take on a SFF tower
This is really neat man. Really enjoyed reading through your post and look forward to seeing more progress in the near future :)
smallformfactor.net
Hello all,
Current status:
- MB : ASUS ROG STRIX B450-I GAMING
- CPU : Ryzen 7 3700X
- GPU : Gigabyte Raedon RX 5700 XT GAMING OC 8G
- RAM : 2x8GB Corsair Vengeance LPX 3600MHz
- SSD : M.2 2TB Intel SSD 6
- PSU : Corsair SF600 80 Plus Platinum
- Fans : Noctua NF - A9x14 chromax
- CPU cooler : Noctua NH-L9a-AM4 (fan switched to a NF - A9x14 chromax)
Next steps:
1) screw them on
