I built this little guy to bring to LTX this year before the current climate had set in. Figured I might as well show it off somewhere now that the event was cancelled. So here it is, my Power Supply.
Link to the full album on Imgur.
My litte PC.
Cheap little power supply, nothing too special.
Seems ordinary enough.
Cables hanging all over the place and looks fine. But what's that noctua brown doing under the normal fan?
Well, opening it up reveals an STX motherboard out of a Deskmini A300 and a 300w FLEX PSU running an AMD 3400g with 16gb of DDR4 and a 2TB NVMe drive.
Had to do some hackery to get everything to fit. So all these components needed to get moved to the back of the PSU, mainly to make space for the fan but also because I had to ditch their heatsink. So now they just have a thermal pad and dissipate heat to the outside case. Also had to drill some small holes where the standoffs meet the case in order to mount the thing.
Another thing that needed to move was this little capacitor on the front side. I didn't have room for it in the back and the fan didn't leave enough space to leave it where it was. So I got a new capacitor and left the legs long. Threw some heatshrink on them to insulate them and bent it out of the way. Seems to work fine.
Of course I had to include some well shaped plastic behind the PSU to insulate the case, I didn't want any chances of things touching back there.
Like I mentioned above, the fan and the PSU didn't like trying to both exist in the same spot. So not only did those PSU components need to move, but the fan also needed to lose some weight.
There was a lot of the fan frame cut away. The thing is actually pretty flimsy without it being mounted to the top of the case.
I also needed to trim all the front I/O off the motherboard in order for the PSU to sit low enough in the case. That and to fit the GDC Beast PCIe X4 version.
I needed every single millimeter I could get to make the PSU and fan fit together. So much so that I had to bash as flat as I could the little divits that lowered the fan into the case. It may have gotten me only 2mm but it helped a ton.
And since this motherboard was originally supposed to run on an external 19v DC power brick, the barrel connector had to go so I could solder on an EPS 12v cable. And yeah, those solder joints aren't my best work, but those pads are tiny and those wires are massive.
Of course with that GDC connected to the M.2 slot, that means I can run an external GPU.
I ended up going with a Radeon 5700 non-XT as it was the most powerful ITX GPU I could find to actually buy. I had to buy it from Amazon Japan, but at least it was in stock. Oh, and did I mention that all the PSU cables hanging out there still actually work? They actually power the GDC and GPU.
I was originally planning to do this elaborate rear I/O setup, but after making my initial test cuts I was happy enough with the way it turned out that I decided to leave it be. Keep it simple.
A close-up of the rear I/O shows the flaws, but it works fine for me and I was able to keep close to the stock powercord mounting location. It had to move up a little to clear the USB/Ethernet tower, but not by much.
All the parts laid out ready to go with me.
The nice thing about this litte setup is that because it's an APU in there, I don't necessarily need to bring the GPU and GDC with me, but I have the option of having that extra horsepower if needed. I mean I guess it's still pretty impractical to have all those wires all over the place, but hey, no one is perfect.
My litte PC.
