My First SFF HDPlex Build
marqDsade
Hi I am Marc and this is my first post to the forums.
I am excited to share my first SFF build.
marqDsade
Here is an image of what I used in the build. The case is a Geeek A30 case for around 50-60 bucks. I build budget custom gaming pc's and decided to try a small form factor project. I decided to use a HDPlex 400w psu to reduce heat, fan noise and clutter. I made a VR ready build with the A30 Geeek case and a Ryzen 5, GTX 1660, M.2 ssd, 1tb Evo drive, 16 gig Corsair Vengeance memory, Gigabyte AB 350 mobo and rgb light strips. With all Noctua cpu cooler and fans it is so silent even under COD 2019 load. Using PCParts picker helped to determine my wattage and it was only around 325. The power brick I bought on Amazon worked wonders.
Reactions: dealda
