Troubleshooting Update:
After searching for advice on computers just restarting randomly here's what I tried:
- Checked all connections. They were good
- Sprayed everything for dust. There really wasn't any inside the computer at all. The filters in the front and bottom of the case caught it all.
- Disabled automatic restarts.
Anyhow amazingly since Tuesday my computer seems ok!?
I haven’t tried doing any rendering as I need to have my computer up and running so I can work. I did open one of my projects in Unreal and was able to run around in it no problem. Before my computer was shutting down when I tried to run it.
Now I'm wondering if maybe I did something wrong putting together my computer?
I didn't realize that the power supply actually sucks in air. I think this filter is blocking the airflow and causing the problem as there is no way to check the power supply temperature?
I put the filter in front of a tabletop fan to see just how much air it blocks and yeah it pretty much blocks it all.
The power supply is in the front facing forward on the top. The big dust accumulation on the filter is due to the fan right below it.
Here are the fans and cooler for the CPU. They are set up so that the air is going from the front of the case through to the back
Case Airflow
Like I said for now everything seems to be working fine.
I'm wondering if I should turn the power supply so the fan is facing the inside. But then the CPU fans are sucking air in the opposite direction. Wouldn’t this possibly prevent air from going into the power supply fan?
The temperature is really cool inside the case.
Anyhow when I have the time I will try rendering a project after taking off the front panel and filter.
Do you think I need to take the front panel off ( all the time now) or just removing the filter is enough?
My last concern is the amount of dust on the filter. If I take it off all that dust will be inside power supply.
I'm thinking I can cut the filter in half to still cover the fan area at least.
Thoughts ? Suggestions?
