While it's not as innovative as the connector Regack showed below, I was still curious what one could do to reduce the connector size of the PCIe 8-pin (or 6+2-pin) cable.
It started in https://smallformfactor.net/forum/t...rdable-and-elegant-we-need-your-feedback.259/
So while 1mm is a challenge for the future (when I've learned PCB design), I managed to reduce the part that extends past the socket by 50%, from 11mm to 5,5mm.
Don't mind the bad finish and badly sleeved cables, I blame the lens (partly). I also tried a sleeved wire where I put heatshrink just over the clamp that digs into the insulation.
I used a Dremel with a cutting blade and used two files and sandpaper to finish it. I needed to remove crud with a sharp knife and some real needle-nose pincers.
So basically if a company is prepared to get the mold costs paid, we'd have easy low profile GPU connectors.
This took me two hours, of which making pictures was almost half the time.
@Aibohphobia, thanks for posting that [H] link, that's a great read. I can confirm that it is very important to make sure there is clearance for connectors. I learned the hard way...
Doesn't get much lower profile than that
I have a Lian-Li with about one millimeter of slack between the top of the PCB and the case, so I have a point of reference to work from
