Log Mjolnir Air Cooled Oven
Solo
895
1,507
I grabbed a used Mjolnir R from eBay earlier today. Maybe I bought it from one of you. I don't know. Either way, I'll be putting my new LGA 1700 build in it featuring bleeding edge DDR5. I'll update this once I start making PSU cables, which is basically all there is to do in a normal build.
Parts list:
CPU: i5-12400
RAM: 16GB 4800MHz DDR5
Motherboard: Asus B660-I
Storage: 500GB 980 Pro
Cooler: Noctua L9i
PSU: Silverstone NJ450
GPU: I have no idea yet
Solo
895
1,507
I've done the annoying parts of this so far. 24 pin is complete. The L9i fan wires have been shortened. The power button wires have been shortened and routed behind the motherboard. A note on the stock wire used for the power button; it's that kind with a thick, rubbery ass insulation that makes inserting it into front panel connecters a pain in the ass. Never use that kind of wire. For real.
Solo
895
1,507
This is done. GPU is in and wired (EVGA 3050) and the AC cable has been zip tied in-line with one of the bottom fan mounting brackets. That side of the sandwich does not need to be seen. There's really nothing to see over there anyway considering how empty it is. Nevertheless, I've got a machine.
