I am stuck with my options to move to RTX3080, the only 2 boards that can fit this case are the 3080FE and the EVGA 10G-P5-3885-KR. Here is my build https://au.pcpartpicker.com/user/ketos/saved/#view=MztYgs. I would like to be able to expand my options as far as 3080 boards. Finding a board is so freaking hard. I would love to use an ITX case, but the one that I know can hold some RTX3080 is the NCASE M1 (The issue is that it can go up to 300mm :-/ no bueno :-/). Is there any other ITX that I may hold a larger RTX 3080 +300mm? or what other cases would you recommend base on my current setup?
