Hi, I wanna share my build with you guys. I'm a Laker fan, so it's a purple and gold build
Hope you guys like it!
CASE:Meshlicious
CPU :5600X
MB :B550I AORUS PRO AX
RAM :Gskill 3200C14 16g*2
GPU: AMD Radeonâ„¢ RX 6700 XT
Watercool part
CPU :EK-Supremacy EVO - Full Nickel (Original CSQ)
RAD:Bitspower Leviathan SF 280
Fitting: Barrow and Bitspower
pump:Alphacool DC-LT 2600 Ultra low noise Ceramic
reservoir:Alphacool Eisstation 40 DC-LT - reservoir
Frosting surface acrylic tube
Please note that if you use Bitspower Leviathan SF 280, radiator can not be put at the front of the case.
Cable length
CPU:40cm
GPU:30cm
24pin:27cm
I moved all these parts from PC-Q37 to Meshlicious for better ventilation and 280mm radiator.
I put 2 2.5inch SSD at the back of PSU so that the SATA cable would be easier to manage.
3 #6-32 6.5+4 mm copper pillar was used to extend to GPU cable. With this method, I can hide all the cable behind GPU
Alphacool Eisstation 40 DC-LT and Alphacool DC-LT 2600 Ultra low noise Ceramic were used for a silent watercool build.
Alphacool DC-LT 2600 is really silent, and it's OK for a single rad and CPU waterblock.
CASE:Meshlicious
CPU :5600X
Watercool part
Cable length
CPU:40cm
GPU:30cm
24pin:27cm
