Updated my Makerbeam proof of concept #2 with a second lower height base section allowing the build to be converted from a NAS home lab using the original taller base section with a minimum of a 4 bay SSD drive unit and horizontal motherboard – and allowing for a NVMe to SATA adapter in the motherboard’s bottom NVMe slot, to a tower style build with a vertical motherboard with the ability to orient the upper section in three different orientations – the “rear” IO panel facing left, right or vertically. With the IO panel facing upwards, longer GPU’s can be fitted extending through the upper section and into the lower section.
