I have a GIGABYTE GA-H270N-WIFI motherboard. Periodically, Bluetooth devices will disconnect. Bluetooth will either be visible in the taskbar or missing. I find the only way to fix the issue is by manually unplugging the card and reconnecting. It's always firmly connected when I do so, so it's not a loose connection.
Has anyone had a similar issue before?
Figured it's worth asking before ordering a replacement card.
