What's the max radiator size (length)? I'm thinking about moving a build with the EK MLC phoenix watercooling kit into the m1 and the rad+fans dimensions are 295mm x 133mm x 68mm. Is it possible to fit this on the bottom of the case, or would it have to be on the side panel? How much room would there be to move tubing around? (the phoenix has rather long tubes, and I'm cooling a gpu and a cpu).
