Hey!
(Logic Supply MC600 product page.)
So, I know there's a review of the case here and Jay has a video review on his @Tek Everything YouTube channel, but I don't feel like I'm getting the info I need on GPU fitment in the MC600. Has anyone else fooled with the case?
The review here mentions that there's a maximum GPU length of 7.75" (which google converts to 196.85mm) and says it accommodates a "full height" video card. (I assume this means it allows up to the bracket's height in clearance.) What gets me is that the review says "Just make sure you have enough room for your power connector." but doesn't really specify what that means...
I'm considering following Jay's suggestion in the video review and adding either fan mounting or just ventilation, and I might even go so far as to try hitting up a shop with a CNC mill to see if they can add perforations to the entire/majority of the top panel.
So far, my i7-4790K has been doing fine with a little bit of undervolting/underclocking inside of the mini-box M350 so I'm pretty confident that the little bit of extra room will mean my thermals stay fine (especially if I'm adding better ventilation and possibly a fan through modding). I will also probably end up ditching my 2.5" SSD and just use the M.2 drive I have in there... maybe upgrading it.
Here are a few questions I have about the case:
- Does anyone have the list of dimensions for what size video card will fit in the case? With PCI-e power connectors plugged in? (I tried emailing Logic Supply about this.)
- Is there enough clearance for a GPU with (a) power connector(s) and two of the 60mm fans?
- Is there enough clearance above or below the video card for additional fans to be installed?
- Is it feasible to cram any 1060's or 1070's in there?
- Is it possible to upgrade the front panel USB 2.0 ports to USB 3.0?
- Any cool stuff I can do with the replaceable front plate? Or just material suggestions?
