Stalled KIBO K2 DIY | 280 Rad | 15L Desktop | 30L Tower
How far would you go for a DIY SFF Case?! Tick all the choices you agree with!
  • Total voters
  • Poll closed .
Kiborato
42
122
K2 is a 3D-print-first approach Case, aiming to cater to these features:​
  1. 280mm Radiator Support [Hats]
  2. Easy Assembly & Maintenance
  3. Sandwich & Classic 2in1 approach
Early Render [1.8x3.6x2.1cm] | [2.0x4.0x2.5cm]
Structural Composition: Rad-Cage & Core-Cage
Corner Joints
Main specs:
- "classic" & "sandwich" Layout
- 360x180mm Footprint [200mm height without Hats]
13L No Hats | 15,5L 1 Hat | 18L 2 Hats
Hardware support:
- 280mm Rad support
- 340mm GPU length
- NH-U9S support (in "classic" layout)
- PSU: ATX SFX-L SFX
- 2xHDD / 4xSSD
- mini-ITX & mini-DTX
Structure specs:
- 120 hour print time [Hat: 4h/10mm]
- ABS 900g [30% infill 1.6mm wall/top/bottom thickness]
- All 6 Sides removable without tools [magnetic & click-flextures]
- Easier assembly, majority of screws directly accessible without overlapping
More info will be added soon~​
