Production k_ses: k3.93L ( 4070 Ti Super Ventus 2X @ 5.29L )
k0n
239
315
@Madsox Thank you :)
The case being suited for all kinds of modifications was part of the idea. The base holds all cutouts and mounting points that are needed... the card can overhang or be triple slot (sky is the limit). The PSU can be a 250W GaN that fits nicely between card and board or be placed external to the base.
I thought of a wall mounted PC
...or just something flat that you can use as a shell and put the base in.
The current 3.93b (ul) and 3.93c I would sell you for 100€. No paint, no switch and no riser otherwise ready to be used.
When I order/plan a run anyone can raise a hand for anything extra. Just the base, just a cover, one extra cover or just the expansion...
Since you want to immediately mod it and only need the base a future run where I'll use steel might be better for you? It depends what you want it to do but the 3.93b (ul) doesn't hold any threads except for the 6 galvanized steel standoffs.
Reactions: Madsox
Madsox
I thought of a wall mounted PC ...or just something flat that you can use as a shell and put the base in.
When I order/plan a run anyone can raise a hand for anything extra. Just the base, just a cover, one extra cover or just an expansion...
I would like to deploy the 500w GaN,I also would love the power Button (unless you’d prefer I ordered it later or elsewhere) so I don’t have to find a solution for it later.
I’m curious about the aluminium v. The steel. I would prefer whatever weighs the least.
just in case I wanted to know what you’re charging for the 5.93L, but beyond that if you think that the mounting for everything is strong enough I trust your opinion. I didn’t read into why the other person/people in the thread were worried about the resilience of the mounting points… thoughts?
P.s. I’m in the USA and would make the purchase of the straight away…
k0n
239
315
The 500W GaN doesn't fit into the smallest 3.93L configuration, and the 5.12L expansion isn't available currently. I consider doing a 5.29L expansion next, which would allow for this 4070 Ti Super.
It's a regular 12mm. There is no need for it to go from China to Germany and then to the US :)
The steel is ~990g and the aluminum is ~510g.
Both are strong enough for all components, but I wouldn't hang 10kg onto the aluminum version.
I don't know what you mean, but the 3D prints carrying the (brass) heat set inserts in the aluminum version are compatible with the steel version and are a backup plan if anyone should break the steel threads.
PM/DM me. Shipping to the US would cost me ~50€.
k0n
239
315
  • some want to fit the 4070 Ti Super Ventus 2X into their k3.93L
  • the physically identical 4070 Ti Ventus 2X came down in price a little
  • I have a irrational weak spot for fully enabled Die's
Here it is:
242 mm
and 2.5 slot
You can still get involved in the design phase of the expansion/cover, and I can imagine doing some cases in one part (5.29b) rather than 3.93b + 5.29e. If you don't already have a k3.93L this would be cheaper but less flexible (no downsizing from 5.29L).
Reactions: NinoPecorino
k0n
239
315
hi! what about mod for 4070ti Ventus 2x 242*125*51mm?
Add a spacer...
Back then, I found the Ti too expansive for 12GB, and the 4070 had the option of a shorter Twin Edge Model.
Now, with the Super and Ti Super, the Ventus 2X has become more relevant since it's now the shortest 4070 Super, 4070 Ti and 4070 Ti Super.
Arriving early May.
jujudk
130
91
It is the best base for a travel build ;)
The 3.93L config is 999g and the 5.12L config is ~1700g.
Hey Kon, kinda asking a question out of the blue, but i am moving soon so i might be interested in your case again. I do have a question regarding the quoted post, if i were to buy the new 5.29b model, it could act as a VESA mount for my main pc monitor ?
I shrugged it off a year ago but now it does make sense in a cramped space ....
ideally it would be the PC + VESA mount, i would get it in steel for that though i guess (and no extension, case in one poart as mentioned above)
k0n
239
315
Yes, you can see the concept pretty well in this short. I don't think I have any of these "L-brackets" left but it's a very simple part... either I'd make more or give you the CAD file.
Are you sure you're not shrugging of the expandability now? ;)
Nobody wanted a one part and so I didn't make any. All that I had made now is 10× 5.29c and 10× 5.12e... for myself and to have on hand for anyone who had already invested in a k3.93L.
Reactions: L91
jujudk
130
91
Oh my, that mount is really solid ! I would indeed be interested in the k3.93l + one extension (easier to fin a gpu and i can more easily fit the hdplex 500w)
Not buying today though, my matx system will last a bit longer
L91
66
73
www.youtube.com
Arriving early May.
This one piece case with just cutouts, I want one
haribo95
It probably won't fit the Inno3D 4070 Ti Super or is there a few mm extra clearance? It's 2-slot thick only, but 250 mm long.
k0n
239
315
No,... and also the fin orientation is not ideal.
The Ventus 2X 70 Ti and 70 Ti Super better utilize the available space with 2.5 slots and have an ideal fin orientation for direct heat exhaust. Almost the entire hot air is being exhausted at front and back.
Reactions: sos
