Out of the box? ASrock
Removing the superfluous heat sinks over the NVME slots? Gigabyte or MSI.
It should be noted that the ASrock boards have the CPU lower on the board, which means you will only be able to use the Blackridge on sandwich style cases.... and it has right angle SATA ports (not good in sandwich style cases).
My vote goes to the MSI with the USB C front header, but the Gigabyte is fine and comes a bit cheaper.
