Hi everyone!
I was wondering what your experiences are with smaller ITX cases (+-10L) housing relatively powerful hardware (I'm looking at the Zen3 equivalent of the 3700X and a RX 5700 (XT)) and keeping them as silent as possible (let's say whisper level/30-35dB).
Is this possible with aircooling? Most of the sub 12L cases are very perforated, I assume this is necessary to maintain decent airflow and thus temperates? My case sits against a wall on the left side so a perforated panel won't work. And aren't these perforated cases more noisy?
I expect the main challenge will be the GPU. I've been using a blower cooler because it helps move the warm air out and it works fine for my RX480 but for the more powerful GPUs like the RX 5700 XT they simply make too much noise on their own to make them feasible. So I'd expect the only viable option would be a to use an open-air GPU cooler but that might pose some issues with regards to thermals for the rest of the case/the CPU in these smaller cases.
So I'm mainly wondering if a setup like this would be possible with just aircooling and if so which case and components people would suggest/have good experiences with.
If a slightly larger case like the NCASE M1 would easily be able to do this (it does have a perforated left side panel though) I'd be open to that option.
And I also don't mind to go the custom watercooling route but only if there are clear benefits for achieving a silent PC in 10L. I don't really care about overclocking.
What have been your experiences with this? Anyone switch from air to watercooling or from water to aircooling? Is it possible to get a 10L case this quiet?
Thanks in advance and sorry for the probably noobish question
P.S. I've already searched on this forum, r/sffpc and Optimum Tech's videos and haven't been able to find a definitive answer/looking for some real world experiences.
