CPU Internal USB to USB-A & USB-C
JoshSpires
joshspires.com.au
I was looking around to see if there is an internal USB to USB-A & USB-C cable I can use with the Geeek A50 Plus, but couldn't find anything that shows the screws going in from the back.
I did manage to find this one on Aliexpress that uses the PCI-E slot and screws in from the front of the connector. Looking at the images it looks like the screw holes go all the way through so could technically be screwed in from the rear of the connector.
Has anyone done something similar? Just wondering if the screw holes are a standard size and would line up with the ones in the case.
