What i gonna do :
Case : Shyni Snake S400
Graphics Card: GALAX GALAX GeForce RTX 3070 Ti SG OC D6X 8GB 317mm X 113mm X 61mm, 1.3kg (No change, already owned)
CPU : Ryzen 5600x (No change, already owned)
CPU Cooler: Thermaltake AXP90-X53 (height 53mm) (→ replaced with TL-B9 26T fan)
Motherboard: ASRock B550M-ITX/ac d&dcom
RAM: Thermaltake DDR4-3200 CL16 TOUGHRAM Z-ONE RGB Package (8Gx2)) (No change, already owned)
SSD: 1x Samsung 980 PRO 2TB (non-replaceable, already owned)
Power : **CORSAIR SF750 80 PLUS Platinum** (already owned)
Fans: IS-55 12025X2 (top), 9015 (bottom)
I'm going to do some research here and there to get something like this together.
Someone told me that I just need to replace the fan in the system cooler, but where do you usually get them?
Also, I was wondering if I need a fan hub and extension cable separately, and if there are other products besides the basic ones, such as riser cables, etc.
I'm asking these questions because it would be nice to buy everything at once and start building.
