This unusual bit of kit would make an ideal small low power HTPC or office PC.
It's an HP proprietary motherboard IPXSB-DM, which is just bigger than ITX size - approx 17x19cm.
It has an i3 2120T * CPU and standard Intel cooler [see Pic 1]** fitted, along with 2x2GB DDR3 1333.
* This board is limited to 35W Sandy (and some Ivy) Bridge CPUs
** It came with an HP cooler [as seen in Pic 2], and I changed the backplate to allow normal push fit coolers. The original cooler and backplate are available if required
The IO plate is with it, along with the laptop brick that powers it, and the 2 special SATA power cables that will run the 2 drives that it can take.
It is a pretty nippy little rig, and has been running Win 10 on a small SSD very nicely.
Asking less than I paid for it£40 £30
______________________________________
Intel socket 1155 Pentium G620T Low Power 2.2GHz CPU£8 £5
