How much watts for this build
How many watts
  • Total voters
snip4n
I want to build
Gigabyte 750 ti 4gb oc
intel i3
2×4gb ddr3 hyperx fury
Nh-l9i
And idk how much watts that i need to run all of that.
im sry that i still newbie.
ignsvn
By Toutatis!
1,729
1,673
snip4n
ignsvn
By Toutatis!
1,729
1,673
Yes,but sometimes i dont believe them cause last time i building my budget pc.they give me the low watts power supply like 300w only
Actually, for the spec you mentioned in the first post, I also estimate around 300 watt. That's why I said 450 watt should be plenty :)
AleksandarK
/dev/null
May 14, 2017
703
774
You can build something like GTX 1070 and i7/r7 with 300w. But the reason most of the time why people go with high wattage PSUs is that they think that something like 450w is too low or they just want their PSU to run quietly.
KMPKT
3,382
5,936
Maybe I'm way off here, but the 750ti was designed to run off the PCIe slot (75W). Even with an OC edition, I can't imagine the card would pull more than 90W. The i3 likely pulls around 55W depending on the age. I think you could probably run the system off an HDPlex 160W AC-DC and DC-ATX combo.
drunker
49
36
wattage calculators like from pcpartpicker and coolermaster usually give you a good amount of overhead.
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
I want to build
intel i3
Nh-l9i
It depends on your choice of i3, but with a 65w CPU you are looking at 125 watt 3D average with the 750ti, according to my testing. I used the EVGA 750ti SC for these tests. I am missing the peak data from all these as it is a legacy card and I just have a whiteboard...I plan to make a spreadsheet...one of these days. XD
This was my travel system for quite some time though, and it was run off the Pico 160XT and 192w Adaptec brick.
3D used to average draw:
Alien Isolation
Mechwarrior Online
Furmark
Valley
CS:GO
