Motherboard How do I find the pinout of a proprietary header? (Thinkstation P360 Ultra)
CaneTLOTW
I found these links, but did not dare to order yet:
CaneTLOTW
I picked it up and it works great for the 4060, the annoying thing is the fan curve on the P360 Ultra's CPU
I received my ThinkMOD today—P360 Ultra with an i7-12700K and RTX 4060.
To free up the PCIe slot, I had to switch from the 120W cooler to the 65W version. However, after removing the second cooler, I started getting a boot error due to the missing second fan.
Since the ThinkMOD connects to the 4-pin socket for the second fan, I was hoping it would suppress that error—but no luck so far.
Do you have an idea about this?
3D Mark runs fine - Time Spy with 10.829
Nilithium
31
I think it's a requirement based on the specs of the processor; that is, if you have a processor with a 125W TDP, it will demand both fans be running. Mine had an i9-12900 that later got swapped to the T version, it's finally quiet :)
For those later to this thread, I've been running the adapter with the 4060 LP for a while now. Got it through Superbuy!
