How Do I Determine What Size Molex Terminal Pins to Get?
PLAWSO
It's come time in the build process for me to shorten some power supply cables so I can fit the side panel on my PC. The problem I've run into is that I don't know what size molex terminal pins to get in order to do that, and can't seem to find a good resource online to figure it out.
I've gathered that there are three sizes: 0.062", 0.084", and 0.093", but I don't know what I'd be measuring (ie the wire gauge, the male terminal pins' diameters, the existing female pins' diameters, or something similar) to determine which one I need.
I'm not even sure that it matters all that much, if someone could educate me I'd greatly appreciate it!
Specs:
S4 Mini w/ Custom GPU Mount and Grill
Asus Prime H310I-PLUS ITX Motherboard
Intel Core i5-9600KF w/ Noctua NH-L9i chromax.black
Corsair Vengeance LPX 16GB
Zotac RTX 2070 Mini
Crucial P1 1TB SSD
HDPlex 400W NanoATX Combo
Reactions: Soul_Est
PLAWSO
Huh, it probably would've helped if I was looking for the right kind of connector ?. Thanks!!
