So I was deciding on a 5700xt for my Dancase v3 and I went with the sapphire pulse... Which doesn't fit. I need help with how I can extend the side panel out or get spacers so that I can actually put my side panel back on and close up my case. If no one has any ideas, is there a case in that size range like the loque that would fit a slightly bigger than 2 slot GPU? Thanks for the help!
