Help Review Build
kaboombogus
Hello everyone,
I'm looking to downsize my rig. I currently have a Lian-Li PC-011 Dynamic. However, since my job requires me to move and I personally don't like selling everything, buying and building a new rig whenever I move I'd like to keep what I have. I want to know if what I currently have from my mid tower chassis can be transferred to the NCASE M1.
I know I'll have to buy a new motherboard and cooler. If you guys have suggestions please don't hesitate to share.
My CPU is a AMD Ryzen 9 3900X.
PSU: Corsair HX Series, HX750, 750 Watt, 80+ Platinum Certified, Fully Modular Power Supply
GPU: Asus ROG Strix RTX 2070 OC 8GB
RAM: G.Skill Ripjaws V Series DDR4-3200
CPU Fans: Corsair Air Series AF120
Would these pieces fit into the NCASE M1?
Thanks for you help!
2,719
2,854
You can't use the ATX PSU and the full size Strix, only way an ATX PSU fits in the Ncase is with short graphic cards. Get a good SFX PSU like the Corsair SF750.
kaboombogus
Thanks for answering. Would the opposite work? SFX PSU plus full size Strix?
kaboombogus
Yes, the Strix is a tight fit but it does fit. If you use a SFX PSU you will be fine.
Hmm yeah... Do you think I'm able to add my Corsair AF120 CPU fans under the ROG Strix as intake or not possible?
I'm looking at the diagram on the forum... but still not sure...
