Hello, I joined becuse...
Skripka
Cat-Dog Perch Manager
May 18, 2020
463
571
Howdy!
One thing not available is an opportunity to find something else you like. Loads of options of cases out there for ITX these days.
5,948
4,953
Welcome to the forum ! Waiting on a case is the worst, of the first world problems.
Toothy
Thank you. Very much a first world problem! ☺
The current hardware I have for the Lian-Li build, consists of a mATX board, SFX PSU, a 280 and 2x360 radiators. Plus a small-ish D5 pump/res. CPU and GPU on water.
I started doing some CAD package studies around these components and was coming out to something like 26-28L. I understand this a bit larger than most cases built here. However, as I now have the components, I would like to explore my options and work with what I have.
I'm a design engineer by trade, so hoping to apply my skills into something a little different.
Anything you think may provide me inspiration.Then feel free to share. I think I can come to a suitable layout OK, but need to look better at construction. I'll start a proper build / design thread once/if I flesh this out a bit more.
5,948
4,953
Start from a simple box with the motherboard in the center, the 360 radiators at the ends and the 280 radiator in between. The SFX PSU will have a place somewhere without issue. Then take a look at every aspect of that bounding box: what can you do to decrease the sizes ? Maybe overlap the board ? Maybe double-stack the radiators ? Would the size be able to shrink with the radiator parallel to the board (like the Lian-Li O11) ? And so on.
Just let your mind come up with solutions to each "problem" when you try to minimize the build.
