Colorful has listed a 12GB, 2 slot, RGB-less RTX 3060 that's only 182mm long. Design wise, it's got a single fan with partial rear exhaust, and simple look of brushed aluminum and white trim. Boost clock is 1792mhz, which is a very slight overclock. For I/O, you have 3 display ports, and one HDMI port, that is presumably HDMI 2.1.
The MSRP was unlisted at this time.
LINK to the original VideoCardz article that the information and images in this post was taken from.
My take: That's a fine looking GPU. I love the simple brushed aluminum. I love the fact that the heatsink is properly designed to allow a partial exhaust of hot air, instead of blocking it with the fins like most do. It should be a nice upgrade from those of us stuck with ITX only sized cases.
...if you can find one.
