Going to throw together a build around the new low profile 4060 when I get it. This will be designed for DC system so will use a pico box to step down from 28.5v lithium on battery, and step down from 19v on mains using brick. If the X3-ATX-300 has some issue I have the X9-ATX-320 as backup which has better specs but is a bit thicker so won't fit the PURE, but would fit in Stratos X.
Preliminary specs:
Asus B660i
Intel 13600k
AXP90x47 with NF-A14-HS swap
32GB Oloy 6600mhz
Gigabyte LP 4060 deshrouded
Pico Box X3-ATX-300 (16-28v)
J-HACK Stratos X or PURE MKII or custom case tbd
Power source (off grid): 28vdc direct battery
Power source (mains): SlimQ 240w GAN
Volume estimate: 3L - 4.6L
Preliminary specs:
Asus B660i
Intel 13600k
32GB Oloy 6600mhz
