Discussion Gigabyte B650I with Noctua C14 in Streacom DA2
MacroJO
Hi,
I am doing a 'new' build using my old case(Streacom DA2) and cooler(Noctua NH-C14). Does anyone have any experience using these products together? I am mostly concerned that the cooler will not fit with the some of the motherboard expansion cards because it has a funky design. Have not done a build for 6y or so and from what I can tell there are not a lot of good AMD itx choices out there.
Thanks!
Revenant
Revenant Tech
1,674
2,708
Sorry for the late reply.
I don't think many of the members here have any experience with that particular setup. CPU cooler height shouldn't be an issue, but as far as motherboard compatibility goes, your best bet is to check with Noctua themself. They have a dedicated section for it.
https://ncc.noctua.at/
Reactions: Phuncz and rfarmer
