So I was fortunate enough to score an old PC from work for EUR 20.00 - an HP ProDesk 600 G3 SFF.
The machine has an Intel i7-7700 CPU, 32GB RAM and a 512GB SSD, and I was thinking about the viability of using it as a gaming machine by adding a GPU.
Unfortunately, being an OEM prebuilt, the PSU is only 180W, and the PCIe x16 slot is limited to only 35W. So I was thinking of transplanting it to another case, and buying a new, higher capacity PSU so that I'm not limited to a single-slot, low-profile, low wattage GPU. I would also need an adapter cable to be able to use the standard ATX connector with the non-standard power input on the motherboard.
However, I'm not sure how I would get around the 35W limit on the PCIe slot. Would this cable allow me to get around that?
There seems to be a whole lot of conflicting views online about adding GPUs to these office-class SFF machines, for understandable reasons. I'm hoping there is some experience I can draw from here.
PCIE 16X to 16X Riser Card Flexible Ribbon Extend Cable Molex Powered
Buy PCIE 16X to 16X Riser Card Flexible Ribbon Extend Cable Molex Powered for €13.94 with Free Shipping Worldwide (In Stock)
www.moddiy.com
