so that's my new daily driver. really happy how it turned out after all. cost me a lot of money, trial and error! i'm coming off an Antec P6 build, which looked really good, but was really too bulky for my taste. yuck!
here are the specs:
Enclosure: Geeek A30 white and black
Motherboard: MSI B450I GAMING PLUS AC
Cpu: Ryzen 7 1700x
Ram: 2x8gb Teamgroup T-Force Vulcan DDR4-3000
Graphics card: Gigabyte GeForce RTX 2060 MINI ITX OC 6gb
Boot drive: Samsung 970 EVO 250gb
Work drive: Intel 545s SSD 512gb
Storage drive: Seagate 2tb 2.5" mobile hard drive
Power supply: HDPlex 400W + "DELL???" 330w power brick (got it on ebay for 75$CAD)
Cooling fans: Arctic F8 PWM x 2
Started to rebuild the A30 frame:
hdplex snuggly stuck at the bottom of the case. i used rubber feet to "stabilize" it on the case floor, without scratching it, and leaving room around it for the heatsinks to do something. i will probably secure it permanently with standoffs eventually, but since i wasn't sure where it would end up, i preferred the free-floating method for now. it is QUITE snug and stuck there though, with cables being tight and all:
slotting the graphics card in was QUITE a challenge! i had to completely unscrew the two top motherboard holder posts and pry it away so i could slide the Gigabyte card in and connect it. once secured in the PCIe bracket, i was able to screw the standoffs back and everything is secure. 123mm limit for the graphics card is a very precise measurement and i'm not sure it would've been possible. the Gigabyte card is 121mm high.
fitting in the USB3 cable is one of the things i hate the most when building in SFF cases. these damn cables are SO STIFF.
that jank seagate 2tb 2.5" hard drive i got off an external enclosure that died (but the hard drive seems fine, i did diagnostics and tests and it works fine).
front panel secured, graphics card side:
back of the case, with I/O shield luckily in place (like everyone, i forgot that piece a couple times in my life when building computers, lol)! you can see the butchered DC to Flex bracket with the 400W barrel connector screw-in thingy. seems like for all the cracks, uneven edges and crazy glue stains, it's not even visible. i will probably order more of these acrylic pieces and make one without messing it up.
cable management pretty good considering all cables were too long! only the power switch cable that didn't want to stay tight and would just hang. i will try to improve this eventually.
more shots in the complete album:
here are the specs:
Cpu: Ryzen 7 1700x
